Сколько масло лить в АКПП и двигатель?
Отправлено 03 Апрель 2008 - 18:03
Отправлено 03 Апрель 2008 - 18:30
Toyota EU
Celica
Celica 1.8 VVT-i (1999-2005)
Engine 1ZZ-FE + oil cooler Capacity 3,7 liter
Capacity 3,5 liter
Filter 0,2 liter
Use: Normal
Service intervals:
Check 1000 km
Change 15000 km / 12 months
TITAN Supersyn 0W-30
TITAN Supersyn 5W-30
TITAN Supersyn 5W-40
TITAN Supersyn PLUS 5W-40
Transaxle, manual 6/1 6/1 Capacity 2,3 liter
Use: Normal
Service intervals:
Check 15000 km / 12 months
Change 60000 km / 48 months
TITAN SINTOPOID FE 75W-85
TITAN SINTOFLUID 75W-80
TITAN SINTOPOID 75W-90
Transaxle, automatic 4/1 Capacity 4,1 liter
Use: Normal
Service intervals:
TITAN ATF 6000 SL
TITAN ATF 3353
TITAN ATF 4000
Transaxle, manual 5/1 Capacity 2,3 liter
Use: Normal
Service intervals:
Change 100000 km / 60 months
Hydraulic brakes/clutch system
Use: Normal
Service intervals:
Change 24 months
MAINTAIN DOT 5.1
MAINTAIN DOT 4.0
Power steering Capacity 0,8 liter
Use: Normal
Service intervals:
TITAN ATF 6000 SL
TITAN ATF 3353
TITAN ATF 4000
Cooling system + manual transmission/transaxle Capacity 5,7 liter
+ automatic transmission/transaxle Capacity 5,6 liter
Use: Normal
Service intervals:
Change 30000 km / 24 months
MAINTAIN FRICOFIN
Use: First change only
Service intervals:
Change 60000 km / 36 months
MAINTAIN FRICOFIN
All rights reserved. No part of this publication may be reproduced, stored in a retrieval system or transmitted in any form or by any means without the prior permission in writing from Fuchs or Olyslager Organisation B.V.
Although every care is taken to ensure accuracy and completeness in compiling these data, no liability can be accepted for damage or loss, direct or indirect, caused by any errors or omissions in the information.
Отправлено 03 Апрель 2008 - 18:44
Отправлено 03 Апрель 2008 - 19:43
Отправлено 03 Апрель 2008 - 19:48
Celica
Celica 2.0i (1994-1999)
Engine 3S-FE Capacity 3,9 liter
Filter 0,2 liter
Use: Normal
Service intervals:
Check 1000 km
Change 10000 km / 12 months
Engine 3S-GE Capacity 4,5 liter
Filter 0,5 liter
Use: Normal
Service intervals:
Check 1000 km
Differential, from automatic Capacity 1,6 liter
Use: Normal
Service intervals:
Check 10000 km / 12 months
Change 40000 km / 48 months
TITAN ATF 6000 SL
TITAN ATF 3353
TITAN ATF 4000
Transaxle, automatic 4/1 Capacity 2,5 liter
Use: Normal
Service intervals:
TITAN ATF 6000 SL
TITAN ATF 3353
TITAN ATF 4000
Transaxle, manual, with limited slip differential 5/1 Capacity 3,5 liter
Use: Normal
Service intervals:
Transaxle, manual 5/1 Capacity 2,6 liter
Use: Normal
Service intervals:
Use: Normal
Service intervals:
Change 24 months
MAINTAIN DOT 5.1
MAINTAIN DOT 4.0
Power steering
Use: Normal
Service intervals:
TITAN ATF 6000 SL
TITAN ATF 3353
TITAN ATF 4000
Cooling system Capacity 7 liter
Use: Normal
Service intervals:
Check 1000 km
Change 40000 km / 24 months
MAINTAIN FRICOFIN
Отправлено 03 Апрель 2008 - 19:54
Отправлено 04 Апрель 2008 - 04:02
В двигатель твой: 3,5 - без замены фильтра; 3,7 - с заменой фильтра (фильтр обязательно меняй)А если по русски и по человечески!???
при тепмературе от -7 до +бесконечности - 20W50
при температуре от -12,5 до +бесконечности - 15W40
при тепмературе от -18 до +бесконечности - 10W30
при температуре от -бесконечности до +бесконечности - 5W30
(Фотик поломался, я бы тебе фотку сделал таблички)
Производителя выбирай сам, главное что бы не подделка было.
У меня залит кастрол 5W30, на лето хочу 10W30 залить.
А про коробку я твою не знаю, знаю только что жижа называется Type-TIV (тип Т 4)
Да там особо и знать то не надо, на сервисе сколько г..вна сольется столько новой жижи и зальют.
Если полностью менять то надо литров 12-14 я думаю, чтобы промылось.
Попусту стараюсь не болтать.
Отправлено 04 Апрель 2008 - 04:14
а то лью 5w50 и весь в сомнениях.
Сообщение отредактировал Vova: 04 Апрель 2008 - 04:19
Отправлено 04 Апрель 2008 - 15:13
-Придумай ее сам!)))
Отправлено 04 Апрель 2008 - 17:08
Менял себе в прошлые выходные масло в коробке и фильтр (советую заменить) + нужна прокладка поддона 35168-52020 300рА если по русски и по человечески!???
по поводу масла у меня туда зашло 3 литра (на щупе обычно написано название масла у меня было тейп-IV ) на щупе у тя есть 2 риски нижняя на холодной коробке а верхняя на горячей (проверять нужно на горячей) для этого после замены масла нуно не много покататься километров 5 потом останавливаешься на ровном месте выжимаешь тормоз и начинаешь переключать с P-L и с L-P с задержкой 2-3 секунды на каждой передаче далее не глушишь двигатель вынимаешь щуп и смотришь масло должно быть между двумя верхними рисками если это так то все ок ))) удачи...
