Расшифровка vin кода - carfax
#2421
Отправлено 13 Январь 2010 - 11:40
#2422
Отправлено 13 Январь 2010 - 11:46
The vehicle identification number you submitted has been analyzed and summary information on your car is shown below.Title and ProblemCheck: Your vehicle checks out!
OdometerCheck: Your vehicle checks out!
Vehicle Use and EventCheck: No vehicle use reported
Full History: Detailed information available
Your vehicle checks out! AutoCheck's database for this 2002 Toyota Celica GTS (JTDDY32T720057401) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems.
0 Problem(s) Reported: 15 Title/Problem areas checked:
No abandoned title record
No damaged title or major damage incident record
No fire damaged title record
No grey market title record
No hail damage title record
No insurance loss title or probable total loss record
No junk or scrapped title record
No manufacturer buyback/lemon title record
No odometer problem title record
No rebuilt/rebuildable title record
No salvage title or salvage auction record
No water damaged title record
No NHTSA crash test record
No frame damage record
No recycling facility record
OdometerCheck
Your vehicle checks out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 2002 Toyota Celica GTS (JTDDY32T720057401) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage. 0 Problem(s) Reported: Mileage Date Reported
10 04/25/2002
Your vehicle checks out! AutoCheck shows no additional information reported to AutoCheck about how this 2002 Toyota Celica GTS (JTDDY32T720057401)has been used and other events. This includes reported accidents and corrected or duplicate titles and storm area registrations. 0 Event(s) Reported: 6 Vehicle uses checked:
No fleet, rental and/or lease use record
No taxi use record
No police use record
No government use record
No livery use record
No driver education record
0 Event(s) Reported: 9 Vehicle events checked:
No accident record reported through accident data sources
No corrected title record
No duplicate title record
No emission/safety inspection record
No loan/lien record
No fire damage incident record
No repossessed record
No theft record
No storm area registration/title record
Full History
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Report Run Date: 2010-01-13 03:45:44.200 EST
Vehicle: 2002 Toyota Celica GTS (JTDDY32T720057401) Event Date Event Location Odometer Reading Data Source Event Detail
03/06/2002 NY Independent Source VEHICLE MANUFACTURED AND SHIPPED TO DEALER
03/18/2002 KINGSTON, NY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
04/02/2002 KINGSTON, NY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
04/25/2002 NY 10 Motor Vehicle Dept. TITLE
02/19/2004 KINGSTON, NY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
Смешной пробег в 10 миль! Чет не верится.
#2423
Отправлено 13 Январь 2010 - 11:58
как я понял все норм??
Спасибо большое
#2424
Отправлено 14 Январь 2010 - 10:51
#2425
Отправлено 14 Январь 2010 - 11:17
The vehicle identification number you submitted has been analyzed and summary information on your car is shown below.Title and ProblemCheck: Major title or other problem(s) reported
Vehicle Use and EventCheck: Specific vehicle use(s) or events reported
Problem Reported! AutoCheck's database for this 2000 Toyota Celica GT (JTDDR32T9Y0018850) shows a negative title(s) or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems.
1 Problem(s) Reported: 15 Title/Problem areas checked:
Salvage title or salvage auction record(s)
OdometerCheck
Your vehicle checks out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 2000 Toyota Celica GT (JTDDR32T9Y0018850) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage. 0 Problem(s) Reported: Mileage Date Reported
193 07/28/2000
14,942 04/03/2002
14,973 04/19/2002
15,000 04/23/2002
15,087 05/23/2002
05/23/2002 STAFFORD SPRINGS, CT 15087 Motor Vehicle Dept. TITLE (Title #:026957696) (Lien Reported)
05/23/2002 STAFFORD SPRINGS, CT Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
03/13/2003 ELLINGTON, CT Accident Source ACCIDENT REPORTED (Case #:DP503013523)
08/17/2003 STAFFORD SPRINGS, CT Accident Source ACCIDENT REPORTED (Case #:DPS03041692)
08/21/2003 STAFFORD SPRINGS, CT Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
11/04/2003 CT Motor Vehicle Dept. SALVAGE
Сообщение отредактировал Обижуля: 14 Январь 2010 - 11:22
#2426
Отправлено 14 Январь 2010 - 11:37
#2427
Отправлено 14 Январь 2010 - 11:42
большое спасибоSection summaries
OdometerCheck
193 07/28/2000
14,942 04/03/2002
14,973 04/19/2002
15,000 04/23/2002
15,087 05/23/2002
Сообщение отредактировал hotwire: 14 Январь 2010 - 11:43
#2428
Отправлено 14 Январь 2010 - 13:25
Пробейте, плиз JTDFR320320043930.
#2429
Отправлено 14 Январь 2010 - 13:27
#2430
Отправлено 14 Январь 2010 - 13:49
большое спасибо
я в английском не сильно силен, но как я понял вроде нормальная машина или может я не прав?
полиглоты помогите
Salvage title
если я не ошибаюсь это полное уничтожение или стоимость ремонта превышает 75% стоимиости авто!
www.mycarfax.ru рулит, не хочеш бесплатно оплати аккаунт и все ОК!
Обижуля, если не сложно JTDDR32TXY0021921....Пожалуйста!!!
У тебя все ОК!
03/19/2003 EASTERN REGION 85430 Auto Auction REPORTED AT AUTO AUCTION
Сообщение отредактировал Обижуля: 14 Январь 2010 - 13:47
#2431
Отправлено 14 Январь 2010 - 13:57
#2432
Отправлено 14 Январь 2010 - 14:41
Salvage title
прикольно....интересно бы знать что значит это полное уничтожение или ремонт....вообще машина у вас в клубе была раньше, ща фото выложить не могу,не дома, потом мож кину, может кто узнает ее и расскажет что с ней и как....но она с 2004 года в россии я 3 хозяин...короче незнаю, прям расстроился я,но будем надеятся на лучшее
Сообщение отредактировал hotwire: 14 Январь 2010 - 14:44
#2433
Отправлено 14 Январь 2010 - 14:43
#2434
Отправлено 14 Январь 2010 - 14:50
заапись....вот этого не ожидал..в 2003 бита, в 2004 вывезена в Россию...казлы нерусские разбилисалваж - это сильно битый автомобиль
П.С. главное чтобы ездила хорошо и служила
Сообщение отредактировал hotwire: 14 Январь 2010 - 14:51
#2435
Отправлено 14 Январь 2010 - 17:52
Спасибо!!!Salvage title
У тебя все ОК!
#2436
Отправлено 14 Январь 2010 - 20:18
заранее сенькфс)
#2437
Отправлено 14 Январь 2010 - 21:38
проверьте плиз если не сложно тойтоу соляру 4T1CE38P64U834060
заранее сенькфс)
ВОТ
http://mycarfax.ru/r...6075677768.html
#2438
Отправлено 15 Январь 2010 - 10:59
#2439
Отправлено 15 Январь 2010 - 13:23
#2440
Отправлено 15 Январь 2010 - 17:15
